8 volt battery charging.
Jon(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jon(OH) Quote  Post ReplyReply Direct Link To This Post Topic: 8 volt battery charging.
    Posted: 26 Dec 2011 at 12:35am
How  do any of you guys charge 8 volt batteries ? My Wife got me a Diehard charger/maintainer for Christmas it has a 2amp12volt setting and a 4amp 6volt setting.I know this has been asked here before but I can`t seem to find it.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 2:51am
http://www.amazon.com/Battery-Tender-Volt-1-25-Charger/dp/B003D5I66E/ref=sr_1_1?ie=UTF8&qid=1324889373&sr=8-1
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 2:58am
I would charge mine on the 6 volt charge.
been there done that, not doing it again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 6:48am
When my G wasn't charging, I used the 6 volt setting on the charger a couple times. It worked fine.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 6:56am
My battery guy said he could get an 8 volt charger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 7:01am
You could use the 12V  setting but add 5 power diodes(50V,10A) in series.This will reduce the 12V to properly charge the 8 volt battery.
The 6V setting shouldn't have enough 'juice' to charge the 8 V battery. If it did it'd 'cook' the 6 volt batteries..
All depends on who in China designed and made the charger....
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 7:10am
My charger is probably 50+ years old and not made in China. The 6 volt setting works fine. I don't question it, I just use it if the battery gets down to where it won't turn the engine over.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 7:44am
If you charge overnight on 6 volt setting you wouln't overcharge. Then set the charger on 12 volt 2 amp it will push 4 or 5 amps into it on that setting for a short time. be careful not to let it there long it will cook it.
If you have a volt meter you can use that to help prevent from overcharging.
I have a variostat wired in that i can set the voltage anywere that i need. If you can set the charger voltage 1 or 2 above the battery voltage and it takes a couple amps you can sometimes restore older batteries.
The universal answer to all questions is yes, how much do you want to spend?
Lyle124 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyle124 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 7:55am
you can chargr it on 6 volt it just won't fully charge it. Lyle
5040 Bad Boy Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 8:23am
If you just want a 'trickle' charger , find a 9 volt 'wall wart' style ac/dc adapter good for 1-2 amps.An 8 volt battery like 8.8 volts as a 'float' charge.
Nowadays you can buy '9 volt AC adapters' for $5-$6. Better deal than the $60 'battery tenders' which while they have a microcomputer in them aren't really worth money.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 10:15am
As Tuck said, you can charge an 8V Battery on the 6V range setting if your charger is equipped with the 6V range. The reserve will not be high in the Battery, but should be active enough to start the Tractor. I've been successful in the past charging 8 volt versions that way.
Steve@B&B
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 11:04am
I only pay $20 for battery minders, not from HF either.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jon(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2011 at 11:39pm
Thank you for all the info.
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2011 at 10:49am
I use a 6 volt charger o charge my 8volt battery just like I use a 12volt charger to charge my 13.8 batteries for my trucks.
Brian
