712H help |
Seth Souerdike ![]() Orange Level ![]() ![]() Joined: 22 Nov 2011 Location: Cutler Indiana Points: 4113 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Nov 2011 at 9:35am |
my 712H will not run when i turn the key it does nothing it has fresh gas in it im going to try jump starting it if that does not work then im going to be in a fix do you guys think it might be the carborator? or battery? help would be nice thanks.
-Seth |
There are no atheist in foxholes.
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
When you say you "turn the key and it does nothing," do you mean it doesn't crank the engine either??? If it's not cranking, it could be a bad or discharged battery or corroded connections at the battery. Let us know what happens when you try jumping it.
If it is cranking, then do you have spark at the plug?? If you can't get the help you need here, try this site: http://www.simpletractors.com/club2/forum.asp?FORUM_ID=7 Edited by 427435 - 25 Nov 2011 at 10:09am |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
it makes no sound at all when i turn the key.
R.W ![]() Orange Level ![]() Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
Just about anybody should be able to figure out whats wrong here "even this dummy"/
1. Charge battery and clean connections.
2. If nothing happens check battery with a tester. "If bad get a new battery"
3. If still nothing check wires and switches.
4. By now you should have it turning over. If it dosen't start smell the exaust "do you smell gas?"
5. If you don't smell gas then clean the carb and or check that you are getting gas to the carb. If you do smell gas then check for spark.
6. If no spark then check points.
Do the above and report back and tell us whats happening.
skipwelte ![]() Orange Level ![]() Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Its usually one of the neutral start switchs not working. There is one on the PTO lever inside the frame-hard to get at, then there is one one the hydro lever behind the battery. unplug them one at a time and use a jumper wire to short across to eliminate them. Ive used a test lite to see which one is bad also. Good luck
i took it to my grandfathers hes is going to charge the battery then i am going there to help him wotk on it thanks any way. :)
