712H help
Seth Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Topic: 712H help
    Posted: 25 Nov 2011 at 9:35am
my 712H will not run when i turn the key it does nothing it has fresh gas in it im going to try jump starting it if that does not work then im going to be in a fix do you guys think it might be the carborator? or battery?  help would be nice thanks.
       -Seth
There are no atheist in foxholes.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 10:08am
When you say you "turn the key and it does nothing," do you mean it doesn't crank the engine either???  If it's not cranking, it could be a bad or discharged battery or corroded connections at the battery.  Let us know what happens when you try jumping it.
If it is cranking, then do you have spark at the plug??
If you can't get the help you need here, try this site:  http://www.simpletractors.com/club2/forum.asp?FORUM_ID=7
Edited by 427435 - 25 Nov 2011 at 10:09am
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 9:40pm
it makes no sound at all when i turn the key.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 9:52pm
Just about anybody should be able to figure out whats wrong here "even this dummy"/
1. Charge battery and clean connections.
2. If nothing happens check battery with a tester. "If bad get a new battery"
3. If still nothing check wires and switches.
4. By now you should have it turning over. If it dosen't start smell the exaust "do you smell gas?"
5. If you don't smell gas then clean the carb and or check that you are getting gas to the carb. If you do smell gas then check for spark.
6. If no spark then check points.
Do the above and report back and tell us whats happening.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 9:33am
Its usually one of the neutral start switchs not working.  There is one on the PTO lever inside the frame-hard to get at, then there is one one the hydro lever behind the battery. unplug them one at a time and use a jumper wire to short across to eliminate them.  Ive used a test lite to see which one is bad also.  Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seth Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 1:19pm
i took it to my grandfathers hes is going to charge the battery then i am going there to help him wotk on it thanks any way. :)
