7060 PTO Seal |
dustinmars ![]() Silver Level ![]() ![]() Joined: 29 Jul 2013 Location: Arkansas Points: 146 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Oct 2015 at 8:52pm |
Can anyone tell me his to change the PTO seal on my 7060 I noticed some small leakage since I used to tractor to bush hog this year. Thanks!
If it is single speed, remove cover and replace seal. If two speed, drain oil, remove bottom cover, remove nut on inner shaft, pull shaft out back, remove 3/8 bolts behind hub, pry hub out as you loosen bolts, and pull hub out. Catch gears when hub comes out. MACK
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
yep...what Mack says...bush hogging seems to be a little hard on them seals for some reason. have had to do my 7010 a couple times! *hint* when you take the bottom cover off, let drip out overnight...or you'll be wearing a lot of it! (this is ona 2-speed)
Yea I have a two speed
