7060 power shift |
acer ![]() Bronze Level ![]() Joined: 10 Jun 2010 Points: 143 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Aug 2012 at 4:01pm |
is it possible for hyd oil to transfer from rear-end to power-shift section?
dipstick in cab is over full and i don't remember adding any to it for a long time. i have put a little in rear-end recently but i always have to occasionally, from hoses leaking and whatnot. this is on a 7060 black belly thanks |
Yes, there are several places for it to transfer. Most likely place is hyd. pumps. MACK
HagerAC ![]() Orange Level ![]() ![]() Joined: 14 Sep 2010 Location: SE MN Points: 1195 |
Yep, dad worked on one about a year ago with the same problem, it ended up being one of the pumps.
ryan(IN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Bluffton,IN Points: 786 |
On our 7060 marroon belly pd it transfers oil between. Mechanic says its the seal between the rear end and tranny. Haven't got around to fixing it yet.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
okay thanks, i drained power-shift oil down to correct level, ill run it and watch it
maybe ill get lucky and someone just added 2 much to it. |
7060 ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Missouri Points: 1148 |
Just out of curiosity what does it hurt to have the transmission a little over full? It says on the dipstick "DO NOT OVERFILL"
bigbird ![]() Silver Level ![]() Joined: 22 Sep 2009 Location: Franklin, IN Points: 77 |
Had same thing on PD maroon belly, 7060 and 7040. Like above, usually in pumps but could be seals between compartments. We were always told that overfilling could cause seals to start leaking.
I was always told overfilling didn't allow heat to disperse through the casting or something like that.
ryan
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21905 |
Overfilling of the transmission causes heating because the clutch housing starts dragging in the oil level that's too high.
