7045 Rear Wheel weights
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: 7045 Rear Wheel weights
    Posted: 31 Aug 2012 at 1:11pm
I bought some weights for a 7045.  They are the solid ring style, probably ~ 3" thick, must weigh ~ 300-350 each.  I want to put 2 on the left, 1 on the right.  There is a 3 hole bolt circle towards the outside on the tractor as well as on the weight.  There is also a 6 hole circle on the tractor and on the weight, but the on the tractor, it's a 3/4" hole for carriage bolt, but the hole in the weight must be 1 3/4 or 2". . .How do you mount these securely?
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 9:27am
I'll take a stab at this one...... Use the outer three holes. The inner six holes are larger so you can put the 3/4 carriage bolts through to the outside of the casting for section weights or the flower-pot style dual hubs. Anyone else help on this one??
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2012 at 9:43am
If these are the weights your talking about I think the only way there supposed to go is on the inside of the wheel. I mounted mine with the 3 3/4" bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 7:26am
Thanks guys and esp. 7060 for the picture.  It looks like you have 2 weights mounted there, correct?  I was hoping to put those on the outside, but if they're inner weights, that's what I'll do.  I did not know that.  Would be a tight squeeze getting the dual clamps in there, but thought it might have worked.
So, if you could confirm there's room for 2?
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 11:29am
Yes, I have 2 on each side. I think the operators manual says you can put 3 on each side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 12:17pm
Thanks so much 7060.  That's exactly what I have and what I needed to know.
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2012 at 12:53pm
I have a 7080 with 3 on each side...they fit but its close between the weight and the axle.  -Wes
