7040 primer parts
joelsplace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Topic: 7040 primer parts
    Posted: 16 May 2019 at 5:46pm
agcopartsbooks.com shows the primer on page 74 but says "Refer to FUEL SYSTEM - HAND PRIMER PUMP group for components" There is no such group on their site that I can find. Does anyone have that section of the parts book?
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 6:13am
Page 82 shows the parts comes in a kit #74063231 IH has the same kit for less money
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 7:31am
I skipped right over that because the diagram was labeled ether starting system. I'm an idiot.
IH - International Harvester dealer? What would I ask for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 8:56am
Used on model 460 and 560 diesel
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 10:03am
Yep. My 560D has one. They ain't to common though. I'd like that part number.
Edited by exSW - 17 May 2019 at 10:04am
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 10:26am
I put together primer rebuild kits. The parts are readily available from a local pump shop, Agco dealer, or IH dealer. The main problem is the plunger seal gets old and leaks air/fuel. That is only available as a plunger assembly.
Stanadyne number 23457, or
AGCO 74063231 and is about 45-50$. I don't have the IH #
The kits I put together have that plunger, the 2 check valves and 3 orings inside, and with shipping run $68. Those primers are RoosaMaster/Stanadyne built units.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 10:37am
Ordering info please. I sent Devon a pic. Said he'd never heard of one.
Edited by exSW - 17 May 2019 at 10:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 3:16pm
Most of the IH tractors had them removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 4:08pm
injpumpED,  what does your kit come with the the AGCO doesn't?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 4:22pm
The Agco Kit only contains the plunger, and the little hold down ring on the plunger stem.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 4:57pm
I've never seen anyone offer a kit, they just sell the plunger assembly, or the other parts individually.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 5:23pm
I had a wrench want to do away with mine. No. It makes filter changes so much easier. Got to have the dang thing pointed downhill as it is.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 5:26pm
Son just got one from a go and it had the shaft, plunger seal,outer seal And metal cap with locking piece to hold the plunger in. About $40 bucks, pump shop wants $60 bucks
