Print Page | Close Window
7040 primer parts
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=161058
Printed Date: 03 Sep 2025 at 8:44am
Topic: 7040 primer parts
Posted By: joelsplace
Subject: 7040 primer parts
Date Posted: 16 May 2019 at 5:46pm
agcopartsbooks.com shows the primer on page 74 but says "Refer to FUEL SYSTEM - HAND PRIMER PUMP group for components" There is no such group on their site that I can find. Does anyone have that section of the parts book?
Posted By: Alvin M
Date Posted: 17 May 2019 at 6:13am
Page 82 shows the parts comes in a kit #74063231 IH has the same kit for less money
Date Posted: 17 May 2019 at 7:31am
I skipped right over that because the diagram was labeled ether starting system. I'm an idiot.
IH - International Harvester dealer? What would I ask for?
Posted By: Alvin M
Date Posted: 17 May 2019 at 8:56am
Used on model 460 and 560 diesel
Posted By: exSW
Date Posted: 17 May 2019 at 10:03am
Yep. My 560D has one. They ain't to common though. I'd like that part number.
Posted By: injpumpEd
Date Posted: 17 May 2019 at 10:26am
I put together primer rebuild kits. The parts are readily available from a local pump shop, Agco dealer, or IH dealer. The main problem is the plunger seal gets old and leaks air/fuel. That is only available as a plunger assembly.
Stanadyne number 23457, or
AGCO 74063231 and is about 45-50$. I don't have the IH #
The kits I put together have that plunger, the 2 check valves and 3 orings inside, and with shipping run $68. Those primers are RoosaMaster/Stanadyne built units.
Posted By: exSW
Date Posted: 17 May 2019 at 10:37am
Ordering info please. I sent Devon a pic. Said he'd never heard of one.
Date Posted: 17 May 2019 at 3:16pm
Most of the IH tractors had them removed.
Date Posted: 17 May 2019 at 4:08pm
injpumpED,  what does your kit come with the the AGCO doesn't?
Posted By: Orange Blood
Date Posted: 17 May 2019 at 4:22pm
The Agco Kit only contains the plunger, and the little hold down ring on the plunger stem.
Still in use:
Date Posted: 17 May 2019 at 4:57pm
I've never seen anyone offer a kit, they just sell the plunger assembly, or the other parts individually.
Posted By: exSW
Date Posted: 17 May 2019 at 5:23pm
I had a wrench want to do away with mine. No. It makes filter changes so much easier. Got to have the dang thing pointed downhill as it is.
Posted By: old farmer
Date Posted: 17 May 2019 at 5:26pm
Son just got one from a go and it had the shaft, plunger seal,outer seal And metal cap with locking piece to hold the plunger in. About $40 bucks, pump shop wants $60 bucks
