7040 Powershift Parking Cable |
Post Reply |
Red Bank
Orange Level Access Joined: 18 Apr 2018 Location: Germanton NC Points: 1049 |
Posted: 24 Mar 2020 at 7:43pm |
Tractor won’t go in park. We pulled floor pan and tried to lube up cable and work it back and forth. I think I need to replace it does anyone know the Agco number for the cable or recommend aftermarket resource?
MACK
Make sure the small cable is moving shifter far enough. MACK
210Postin
Bronze Level Joined: 06 Oct 2016 Location: Ellisville IL Points: 151 |
have cables instock for everything on that tractor
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3158 |
I just got a 7040 with the same problem. I put new cables in as suggested. It shifts much easier but still wouldn't go into park. The short cable I could not shorten enough to pull into park.
Look at the area I circled. The curved link is moved when you put shift lever in the park gate. That curve area was extremely worn so I took it out and built it up with a few passes with the welder. Goes into park much easier now. |
Orange Level Access Joined: 12 Sep 2009 Points: 19585 |
An area that needs some spray lube shoved down in there a couple of times per year.
plummerscarin
Good idea. Chain/cable lubes?
Anything is better than nothing. Chain lube probably stays longer.
Post Reply | |
