7030 trans/rear end problems
Matt80t View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt80t Quote  Post ReplyReply Direct Link To This Post Topic: 7030 trans/rear end problems
    Posted: 26 Nov 2011 at 11:50pm
I've go a 7030 that is pumping fluid from the transmission to the rear-end. I'm a diesel mechanic and have 14 years experience in tractor /trailers but little or no eperience with farm tractors. Frankly, almost all of my tractor expreience has been on a john deere pulling tractor.
I'm assuming that there is a bad seal between the transmission and rear-end but it will fill the rear-end till it overflows which makes me think that its not a seal since the fluids should equalize between the two. Anyway, before I tear it apart I was hoping for a little input from someone who has had this experience. I do have an original 7030 Allis-Chalmer service manual but I'd like a little direction before I start working on it.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 6:55am
 It is the seal in the gerotor pump if it does it only running. Most likely spun the bushing through the seal. Pull all 3 pumps out the bottom. Not a big job but oiley and costly.  Be a good time to replace the seal on pump drive shaft.  MACK
