7010 power director trans. Brake adjust
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Topic: 7010 power director trans. Brake adjust
    Posted: 26 Mar 2019 at 4:55pm
I have an allis dealer service tech. Binder plus operators manual and I T manual. Cant seem to locate in either how to adjust clutch pedal for transmission brake. Thanks
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 9:05pm
Most likely clutch cable
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 1:24am
adjustment is ahead of the firewall up in plain sight, the one end of the cable attaches there, and when you look at it, and want to adjust it, adjust it the opposite way that you would think it should go! i'd hafta go look at mine again to tell it better! lol
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 6:09am
A new clutch cable fixed my 7050. My brother's 7030 needed new pivot linkage bushings. IIRC you can loosen the cable u-bolt clamp and pull the cable forward so there is no clutch pedal free travel. That may do it for you.
Edited by Lonn - 27 Mar 2019 at 6:10am
Wink
I am a Russian Bot
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 9:38am
Just replaced a cable a few weeks ago.  You would be surprised how easy the clutch is to push with a new cable and bushings.  If those bushings are bad adjustment won't help you much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 10:01am
I will change it later to clear up the writing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 10:11am
That's a nice and helpful picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 8:17pm
Thanks guys. Probably will just get new cable ordered. Thanks. Cory
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2019 at 8:26pm
I tried to replace that picture or edit the post, guess I can't.  Here is another picture with some better fonts.  Tried a couple of different colors black seemed to work best.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 7:11am
It doesn't take a lot of wear on those bushings. At least on my brother's 7030 it didn't. After I did everything else I replaced the bushings which looked good and that seemed to have been the fix.
If your knee gets sore from clutching then the cable is junk. That's how my 7050 was and it was hard to shift without grinding in low gear so I just avoided low then the cable finally snapped. It shifted better than ever with a new one.
Great illustration LB
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 11:39am
Thanks guys. Very helpful.   Cory
Very in depth LB0442 thank you.
