6080 rear wheel studs
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: 6080 rear wheel studs
    Posted: 06 Aug 2017 at 8:31pm
I would like to put 30" rears w/ steel centers on my 6080 to get the weight down a bit and get a little better mowing speeds. I was wondering if the studs are threaded far enough for steel wheels, I am having trouble getting the cast centers off the hub. If they are not, I might just put a set of un-loaded bias 34's on it so I don't have to take the centers off...
ALLIS EXPRESS!
This year:
Austin IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 8:55pm
Not sure if i can answer ur question but.. i took off my 28's steel center from my 6070 and put 34 cast centers on it. I had to have longer studs. I have the shorter ones if u need them.
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 8:57pm
Eldon, I have an Allis 180 and it had 18.4X28 with steel wheel rims. I traded with a tractor parts wrecker my wheels for 16.9X34 cast wheels. I had to buy longer bolts grade 9. It made the 180 move a lot faster on the road. I liked the 34 wheels for collecting sap when making maple syrup, rolled over rough ground better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 9:04pm
The 16.9X34 cast rims were off of a 6080 that had new tires mounted and my 18.4 tires were in rough shape.
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 9:10pm
Will need some type of spacer if going to steel centers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 10:55pm
Yes I finally got the centers loose and see they are only threaded part way. I had some 1/2" thick 8 on 8 rings that I put on first, so I am not on the pilot diameter. I then put the wheels on and then a spacer, then the washer and nut. I will see if they stay tight. Not a lot of heavy use planned, so they should be fine. I may have slowed the tractor down too much, tho. I think I probably dropped 2500 to 3000 lbs off the tractor tho! Those Conti Radials with fluid were heavy! Maybe the weight close to a 6060 now??
ALLIS EXPRESS!
This year:
