6080 Oil Pan Gasket Question
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: 6080 Oil Pan Gasket Question
    Posted: 02 Aug 2017 at 5:27pm
All,
I am getting my 6080 engine back together, and need to put the oil pan on.  I replaced the front cover gasket during this repair, and the gasket overhangs the engine block, into the space that will be occupied by the Oil pan and its gasket.  The picture below show the overhang.
My question is what do I do?  Should I cut it with a razor, so the oil pan gasket seats to the block?  Do I fold it over and let the oil pan gasket mash into it?  (This one seems illogical to me)
Thank you,
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 6:38pm
Originally posted by Johnwilson_osf Johnwilson_osf wrote:
All,
Thank you,
John
On the assembly line that gasket and the front plate gasket where both trimmed off flush to the oil pan rail with a "very sharp" gasket scrapper (Snap on #CSA12 USA) and a dab of black Permatex was applied to both gaskets and on both oil pan rails and then the pan was attached to the block.
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2017 at 8:37pm
just cut cut off with razor
