6080 grill shroud repair
skateboarder68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skateboarder68 Quote  Post ReplyReply Direct Link To This Post Topic: 6080 grill shroud repair
    Posted: 05 Jan 2012 at 3:30pm
Anybody know someone who could fix a broken grill shroud on a 6080.  I think that's what u call it - the fiberglass part around the grill.  Here's a picture of the broken one
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 5:54pm
i took mine to the local body shop, as ive never worked with fiberglass
Cowboy UP
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 7:53pm
      I have repaired the fiberglass grill on several of the 5040s because they fell off alot. It is not hard at all, go to any NAPA and get a fiberglass repair kit, mesh, resin,etc. Sand the area to be worked on enough to scuff up, cut the mesh over lap the repair area, make sure you have sanded an area larger than the mesh that you cut, mix up enough  hardener to apply over the mesh to create good adhesion. Several applications will be needed depending on the damage. Sand to finish (200-400 grit) Paint with desired finish.
This page was generated in 0.110 seconds.
