6060 3 pt wont raise
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 6060 3 pt wont raise
    Posted: 30 Sep 2017 at 11:29am
Got a 6060 that I took the bottom screen filter out and cleaned it up, shortly after that the 3 pt got funny sometimes would raise sometimes not; now it quit raising completely, cables all move freely, I unhooked them moved the whatchamagittit by hand and nothing differt, whats the best way to get access to the valve? Thinking dirt or something moved around and lodged in the valve ??!!
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2017 at 11:43am
Air bubble?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2017 at 12:46pm
No doubt that, wish tho, been running it for a bit like this, would have thought it would've worked out by now
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2017 at 6:26pm
If the remote outlets don't work either, it's a pump issue. Does the Power steering work???????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2017 at 6:55pm
Everything else works good,,, has a loader on it works fine
Edited by DougG - 30 Sep 2017 at 6:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2017 at 6:59pm
Both levers have to be all the way rearward for hitch to raise.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2017 at 9:36pm
Remove seat and plate to access valve. There is a plug that takes about a 15/16 socket. Under it is a spool about 1" in dial. And about 1 1/2 long. Lift it out, clean it and seat. Should work.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2017 at 10:30am
Ill try that Mack thanks
sherman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sherman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2017 at 12:50pm
i had issues with my 3pt on my 6080 a few years ago, check your filter and the sealing orings on it. its a red filter and the o ring has to seat proper, mine was not and it was sucking air, sometimes it would work sometimes not. you can also have 2 orings in there if the last guy did not remove one. hope that helps.
