45 WC final drive
city farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote city farmer Quote  Post ReplyReply Direct Link To This Post Topic: 45 WC final drive
    Posted: 09 Apr 2017 at 10:11pm
Getting ready to tear final drive apart on my 45 WC, any tips I need to know before I get started.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2017 at 10:18pm
Is it a WD45 or a 1945 WC?    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote city farmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 7:45pm
1945 WC
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 8:08pm
Take pics. of it as it comes apart so you can get it back together without a lot of head scratchin!!! thanks; ac fleet
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2017 at 9:08pm
Not a bad job except for that 70 year black 140 weight oil. It will even stink.     MACK
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 10:17am
Mack, is 140 weight what I should use in the final drives of my WF?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 9:36pm
Any new type oil is fine in there. The problem with thinner oil is they don't have good oil seals around wheel hubs. Light oil might leak worse, but easier to clean up than 80-90 or 140.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 10:53am
Thanks, Mack!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote city farmer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2017 at 5:20pm
Has any body tried using some Lucas oil? I have used it on motors that have leaks, with some good luck.   Thanks for all your info.
