3 point hitch arms won't stay up,power steering is
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Topic: 3 point hitch arms won't stay up,power steering is
    Posted: 09 Jun 2015 at 5:22am
My d14 3 point hitch arms won't stay up and sometimes the power steering takes a min to work... any thoughts? All fluids are full
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2015 at 7:26am
There is a hold posion valve on pump that could be bad or foreign materal in it.
  Steering, make sure suction line is tight and no leaks.  MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2015 at 4:46pm
Both of your concerns are separate and not related.
Regarding the hydraulic lift arms not staying up.  Could be that the lift cylinder needs new seals, or the oil line that feeds the cylinder has a hole and needs replacing.  Either way, the rear housing needs to be taken off to look at these items.
About your steering, if it works fine after a minute, it might be something as simple as being a little low on fluid, or it is sucking in air through one of the lines.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2015 at 5:30pm
You might wanna drain the power steering sump,  its under the radiator and can get moisture in the oil causing problems, there is a plug under the front housing to drain it.
This page was generated in 0.057 seconds.
