Print Page | Close Window
3 point hitch arms won't stay up,power steering is
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=107351
Printed Date: 10 Sep 2025 at 7:10pm
Topic: 3 point hitch arms won't stay up,power steering is
Posted By: mike 44
Subject: 3 point hitch arms won't stay up,power steering is
Date Posted: 09 Jun 2015 at 5:22am
My d14 3 point hitch arms won't stay up and sometimes the power steering takes a min to work... any thoughts? All fluids are full
Posted By: MACK
Date Posted: 09 Jun 2015 at 7:26am
There is a hold posion valve on pump that could be bad or foreign materal in it.
  Steering, make sure suction line is tight and no leaks.  MACK
Posted By: DSeries4
Date Posted: 09 Jun 2015 at 4:46pm
Both of your concerns are separate and not related.
Regarding the hydraulic lift arms not staying up.  Could be that the lift cylinder needs new seals, or the oil line that feeds the cylinder has a hole and needs replacing.  Either way, the rear housing needs to be taken off to look at these items.
About your steering, if it works fine after a minute, it might be something as simple as being a little low on fluid, or it is sucking in air through one of the lines.
Posted By: skipwelte
Date Posted: 09 Jun 2015 at 5:30pm
You might wanna drain the power steering sump,  its under the radiator and can get moisture in the oil causing problems, there is a plug under the front housing to drain it.
