20.4 x 38 on a 190??
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: 20.4 x 38 on a 190??
    Posted: 05 Aug 2012 at 12:04am
I did a mowing job for a guy today and there were a set of 20.4 x 38 tires and rims that he said he would have to take to the dump.....I said I would come back and get them if he didn't want them. So, looks like I have a set of big tires...wondering if all 38" centers on a D19/190 are set up to handle both spin-out and bump rims....these are bump rims. Would also be looking for some clamps.
ALLIS EXPRESS!
This year:
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 12:21am
Will look like this?
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 7:24am
spin outs use half the clamps the double bevel rims use all of the clamps hth
     Shawn
190XT,D17and 7045
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 9:57am
I have some clamps from 34" wheels, but they are heavy so I would assume shipping would be quite spendy.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 10:18am
Probably 20.8 x 38. That is the next standard size above 18.4. Be careful, you may not be able to pick one off you if it falls on you.
The fronts might need 11.00 x 16 to match.
Gerald J.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 2:49pm
I've always thought that 20.8 x 34" tires would be good on a one ninety. I had that size with axle duals on an early 4430. It's a size that I rarely see. IMO 20.8 x 38 is too much tire for a one ninety.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 10:44pm
Calvin I saw a 200 at an auction one time with 20.8x34, it looked good. That size is kind of an odd size though. I wonder what a 190 would look like with 24.5x32 or 23.1x34 later is also a less common size??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 10:59pm
USPS Flat rate boxes!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 11:02pm
I was thinking of running them unloaded on a mowing tractor....better floatation. Aren't they the same height of an 18.4 x 38?
ALLIS EXPRESS!
This year:
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 11:13pm
Pretty sure they're a little bigger.  If I remember, 18.4x38 is about the same size as 20.8x34, so that would put 20.8x38 around 18.4x42 size.  BKT shows 20.8x38 as 550mm diameter and 18.4x38 as 467mm diameter.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 7:17am
A 20.8 x 38 is a lot taller than an 18.4 x 38. They are the same height as an 18.4 x 42
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2012 at 9:05am
LOL I need to read the entire topic better so I don't just repost what the last guy said
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2012 at 9:13am
If they are free, lean one up against the one mounted on the tractor, then you will know my friend!!!
Still in use:
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2012 at 12:45pm
If I did pictures I'd put my 65XT with 23.1/34's on here. Seems I have alot more room left over in the old stlye fenders than the one with late fenders pictured above. I believe they were off a deere combine.
