2 bottom SC plow |
littlemarv
Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Topic: 2 bottom SC plowPosted: 26 Jul 2019 at 9:42am |
I need another plow like I need a hole in the head, but I don't have a two bottom and I couldn't live without one any more. Thanks Facebook Marketplace.
I assume its a #52 plow, but I am wondering about the solid lift link on the left side? Never seen (or noticed) one before. Don't see anything in the manual about it, and the manual covers both pin hitch and SC type. So there, another one saved from scrap. Any info would be appreciated. I have a three bottom SC plow, the WD pulls it OK in first gear, but its a handful when you get into a wet spot. This one should be a breeze in second. Thanks for looking.
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25263 |
Posted: 26 Jul 2019 at 9:48am |
I've got a 3 btm, same 'solid bar' setup. I was going to make it a 2 btm as one pointy piece is busted and still, after 6 years ,haven't got around to welding a patch in. I should just sell or 'find a new home' for it but Murphy says my 3 btm will need parts..... Jay
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1046 |
Posted: 26 Jul 2019 at 10:12am |
Not sure but it might be a model 63 with the slanted beams the bottoms are mounted on.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 26 Jul 2019 at 10:18am |
#62. Two bottom. A #63 would be three bottom
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2077 |
Posted: 26 Jul 2019 at 10:39am |
yep, a #62! I have a few plows that have the solid lift link on the left side.
Thanks & God Bless
Dennis |
littlemarv
Posted: 26 Jul 2019 at 11:33am |
OK, so where does the 60 series come into play? Is the 60 series an improvement that replaced the 50 series?
littlemarv
Posted: 26 Jul 2019 at 12:48pm |
And what is the "shock shoe" for? It's a little piece on the landside that swivels on a bushing.
Edited by littlemarv - 26 Jul 2019 at 12:48pm |
JoeO(C-MO)
Joined: 12 Oct 2009 Location: 3rd Rock > Su Points: 132 |
Posted: 26 Jul 2019 at 1:11pm |
That always seemed backwards to me, since the operator usually dismounts on left side , walk around the plow across a furrow, on plowed ground, bend over further making the adjustment. In my opinion, why not make the adjustment on the land side! IMHO
Edited by JoeO(C-MO) - 26 Jul 2019 at 1:14pm |
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts. |
JoeO(C-MO)
Posted: 26 Jul 2019 at 1:17pm |
just that, keep from breaking/bending the share point if plow drops too fast
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55292 |
Posted: 26 Jul 2019 at 5:54pm |
As you can see from the pics, a 60 series has better trash clearance... Well since There is no pic of a 50 series, take my word for it, the 60 series with the bent shank just clears trash better... ![]() Also uses a more modern, straight share... ![]() ![]() Edited by DiyDave - 26 Jul 2019 at 5:59pm |
Gerald J.
Posted: 26 Jul 2019 at 10:13pm |
There is a post over on the Knowledge forum about plows with detailed descriptions of the various AC families of plow frames and a link to a plow frames parts book and a plow bottoms parts book.
Gerald J. |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4280 |
Thanks(1)
Posted: 26 Jul 2019 at 10:17pm |
Congrats on a fine purchase. I feel your pain!! I can't help myself either, bought a model 52 back in April, that I REALLY needed.
Michael V (NM)
Posted: 26 Jul 2019 at 10:31pm |
I noticed the solid link on a plow here at Hutch today...I know very little about plows..it just seemed to stand out
IBWD MIke
Posted: 27 Jul 2019 at 9:01am |
I'm speculating a bit here, think the non-adjustable link was just a cost reduction move on AC's part. The adj. link on only one side achieved everything needed and way cheaper to produce. For us, two less threads to rust solid to have to free up!
