1959 D-17 leaking hydraulic fluid.
farmboy59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy59 Quote  Post ReplyReply Direct Link To This Post Topic: 1959 D-17 leaking hydraulic fluid.
    Posted: 08 May 2017 at 12:35pm
I have a series one D-17 and it leaks hydraulic fluid from the inspection hole in the bottom of the torque tube. The best I can figure it leaks from around the input shaft. Just want to know what part I have to get before I tear into it to fix it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 5:17pm
There is a shaft seal in there. I forget if it was built with just one or two, but I know there is room for two. When I had my D17 apart I stacked up two seals. You'll have the engine out so now is also a good time to put a new clutch in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy59 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 12:19pm
Yeah I figured if I've gotta split it I mise well look at the clutch.
36 WC, 50 WD, 51 CA, 55 D-14, 59 D-17, 62 D-19, 73 610
