1947 WC manifold/exhaust pipe
jrsinn83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrsinn83 Quote  Post ReplyReply Direct Link To This Post Topic: 1947 WC manifold/exhaust pipe
    Posted: 26 May 2017 at 1:50pm
In the long process of putting back together my restoration project I have lost the exhaust pipe. My dad has informed me that their is a metal pipe that he thinks screws into thread in the manifold where that exhaust pipe goes. My question does anybody know the size or where I can bye this pipe to screw into the manifold hole? The way my dad explained it is that your screw the pipe into the manifold and then put the exhaust pipe over it??? Any info would be much appreciated.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 2:40pm
unless it has the later d17 manifold it wont have a screw in pipe.  early manifolds had a pipe section that slid in and was locked in with a bolt once the muffler was on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrsinn83 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 3:25pm
Do you know what that manifold looks like? Mine has a front square plate with four screws
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2017 at 7:26am
Go to agcopartsbook.com and look at the parts diagram. Cal is right, the screw in pipe was not until the D17 series IV. The WC had a slide in pipe with a bolt holding it in.
prettyview View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote prettyview Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2017 at 7:56am
I have a WF and muffler just slides over manifold and bolts with 1 bolt and the manifold is the same as you describe
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrsinn83 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2017 at 8:03am
So does the after market mufflers come with that set up or do I need to find the pipe you set in there?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2017 at 8:36am
Screw in pipe started with the series 2 D17.
AaronSEIA
This page was generated in 0.289 seconds.
