1947 c Loud whinning noise in rearend |
craigreavley
Topic: 1947 c Loud whinning noise in rearendPosted: 23 Sep 2011 at 1:34pm |
What would cause a loud whinning noise in the rearend of a C. It makes the noise in all gears, only when tractor is moving. Both sides are evenly loud all fluids are full. If you jack up one side and spin the wheel by hand it is heard as well.Everything works as it should it is just really loud in all gears. I have several Cs and there is always some gear noise but this one tractor is by far excessive. The noise seems to be coming from right at the center of where the two axles go into the center transmission.
Gerald J.
Posted: 23 Sep 2011 at 1:58pm |
Pinion to ring gear mesh, or bearings on pinion and differential, or all 6 (4 bearings, two gears).
Gerald J. |
craigreavley
Posted: 23 Sep 2011 at 2:06pm |
I have another complete transmission and rear end for a c that is good. Is it easier to change rearend, or try to tear this one aprt and fix???
nsula_country
Joined: 10 Mar 2011 Location: NW Louisiana Points: 218 |
Posted: 23 Sep 2011 at 2:37pm |
My Farmall 504 has sounded like that for more than 10 years. I think it is called wear. So far it is not noticeably worse from one use to the next. Also it is a constant sound, not like broken teeth.
CT
2014 LS P7010C, 1962 Farmall 504 Diesel (1st tractor) w/ 2008 Koyker 220 FEL, 1968 Allis Chalmers 180 Diesel, Komatsu PC38UU-2 Excavator, Various attachments for all!
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Posted: 23 Sep 2011 at 7:31pm |
My C has a similar noise. It stops when the clutch is in and everything stops turning. It does it in neutral also but gets worse the higher gear you're in. Third is terrible. I believe mine is in the trans since it does it in neutral.
