1940 Model B groans while driving
Shoe3669 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shoe3669 Quote  Post ReplyReply Direct Link To This Post Topic: 1940 Model B groans while driving
    Posted: 11 Jul 2017 at 12:17pm
Just picked up my first A/C tractor, its a 1940 Model B.  When in 1st gear the tractor groans from what sounds like the transmission.  Do I need to add some oil/fluid somewhere?  Any idea what could be causing this noise?
Thanks for the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 12:24pm
Ain't been around a B but you ought to hear first gear in my WD which dad bought new.Yes it has grease.Straight cut gears are know to be noisy. You may not have a problem.
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 12:58pm
Mine does the same thing. Going to check the final drive lubricant after I pull off the mower
D17 Series 1
Allis B- 1939
Allis B- 1945
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 2:20pm
Mine does it in all gears. Sometimes it's a groan, but usually it's a whine Wink
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 2:38pm
There is a big square plug by your left heel when you sit on the tractor, it should be full of universal transmission fluid if you have a hydraulic pump on the tractor, otherwise 80-90 gear lube .  The final drives (bull gear) gets 80-90 wt gear lube , add thru small pipe plug on side of bull gear cover,  until full to level of plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shoe3669 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 3:10pm
Thanks a bunch for all of the reply's.  With the advice posted above, I'll check the fluids and top them off as needed.  If the noise remains I'll consider it normal...until there's a catastrophic failure of some sort LOL
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 4:46pm
Considering the fact that you're 1940 B is SEVENTY SEVEN YEARS OLD.  That Ain't Bad if that is all there is.
As said above if you have a hydraulic be certain to add hyd tran fluid if the oil is low.  And thinking again it could be wise to drain and refill.  Can't Hurt.  Remember, if you have a PTO Hydraulic there is a drain plug in the bottom of the PTO.  Don't forget to drain that too.  If you do not have a hydraulic you could add the heavier oil as said above.  When my father first sold them they came through with 140 in the rear.  It was the dickens to get out when hydraulics were added.  We used kerosene to clean out the transmission.
In any event you have one of the most dependable tractors Allis Chalmers made.  As you can see with normal maintenance it will give you a lifetime plus of work.
Take good care of my favorite.
Good Luck!
Bill Long
Edited by Bill Long - 11 Jul 2017 at 4:51pm
This page was generated in 0.058 seconds.
