190xt gas to diesel |
Rls0170
Topic: 190xt gas to dieselPosted: 7 hours 20 minutes ago at 4:43pm |
If I want to put a 2800 diesel out of an F combine in place of a 2800 gas will the parts that need to be changed work from the gas (timing covers, timing gear and I've heard the cam). Is there anything else major?
Michael V (NM)
Posted: 6 hours 58 minutes ago at 5:05pm |
front and rear plate, water pump. front plate for mounts and hydraulic pump, jus hafta pull the cam, or camthere gear to change front plate. the rear has the mounts for the front axle pivot, combine does not..
this is jus a few things I can remember, there maybe more,, hopefully others will chime in
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3623 |
Posted: 6 hours 19 minutes ago at 5:44pm |
You will have to have front covers from a diesel with hyd pump drive - your 2800 Gas does not have provisions for a fuel pump and the F combine has no provisions for the hydraulic pump drive. You may have an issue with the front crank pulley - the gas and diesel are one part number off - an XT would work - there is limited space and a crank pulley off a M2 will not work - ask me how I know.... the gas and diesel might interchange as I have no idea what the difference is.
Posted: 2 hours 25 minutes ago at 9:38pm |
Gas and diesel solid cast iron crank pulleys are the same except for the timing marks are on the right side for the diesel and the left side for the gas. You'll have to use the tractor flywheel with the combine ring gear transferred to it.
Edited by DrAllis - 2 hours 23 minutes ago at 9:40pm |
