190XT Gas governor spring
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Gas governor spring
    Posted: 20 Jul 2012 at 11:16pm
I think I need a governor spring for my 190XT gas. If I adjust the high idle according to the book, the low idle is too high (won't go to the stop on the carb). If I set it so it will go to low idle, then it will only rev to 2000 rpm. Called SLI and AGCO replaced the spring assembly (2 Parts) with 3 seperate parts and they are very proud of them. They now have an auxillary spring. Anyway I need a good spring if anyone has one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2012 at 5:21pm
 If you have to, you can drill a new hole on the governor arm up 1/2" or so (from the original hole) to reach your high idle specs. It will require reworking the throttle cable anchor bracket just a bit to allow for a straight line, but that can be done easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2012 at 9:39pm
Thanks. I had a couple of ideas, but I like the redrilling better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 6:17pm
Found a new governor spring assembly. Installed it and I now have both high and low idle at the proper rpm and the governor works just as it should.
This page was generated in 0.093 seconds.
