190 xt series III questions
rudyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Topic: 190 xt series III questions
    Posted: 30 Nov 2016 at 7:41pm
Looking to trade for a 190 xt
I have one already so a little familiar with them
The one I'm looking at fired right up after sitting for a couple months.
It was fairly cold out as well 38 or so
The tractor had to warm up for 10 minutes before the hydraulics would work, after that they worked great
Any ideas
Also he had tied the drain plugs together for a equalizer tube, I'm assuming the seal between two resistors has gone bad
Any idea on repairing the seal, time it takes cost etc
Thanks for any advice
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 9:41pm
Check all connections between sump and hydraulic and replace front seal in hydraulic pump.
If the two oil compartments are tied togather, it needs split and replace seals. May also need the housing the PD slides into replaced.    MACK
