190 xt Hydraulic line leaks
slip knot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slip knot Quote  Post ReplyReply Direct Link To This Post Topic: 190 xt Hydraulic line leaks
    Posted: 22 Nov 2016 at 8:12pm
last year I got the XT running with a new clutch and rebuilt the power director. While I had it apart I rebuilt the hydraulic controls and replaced the orings in the line connectors. Last week while loading hay I found a small stream of oil coming from the hydro controllers. Where the lines go into the connectors. These were a real pain to replace the orings and I really hate to go back in there without any assurances it will fix the problem. Are these orings "special" proprietary seals?
Is there a replacement end for these lines or do you have to replace the whole line?
I plan on keeping this machine and want to fix this issue once and for all. What would the good folks on here recommend?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 9:22pm
Replace the lines with later style lines. It is a never ending job replacing Owings + a real pain.         MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote slip knot Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 9:46pm
are the new style lines available from AGCO? Aftermarket?
I'm not sure I want to start trying to piece together a set from junkyards.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 7:33am
No aftermarket, I'd try to get a set from a 200 out of salvage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 10:56am
Those old design lines/connections were a really bad idea. I've always thought there was some door-to-door peddler that showed up in Milwaukee one day and sold A-C a trainload of those things for pennies apiece. They sure didn't stay with them very long.
