185 PTO Seal
geb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geb Quote  Post ReplyReply Direct Link To This Post Topic: 185 PTO Seal
    Posted: 07 Oct 2012 at 8:20pm
Can the seal around the PTO shaft on am AC 185 be replaced by cleaning and polishing the shaft, pryiing the old seal out with a screwdriver or seal puller and just tapping the new one in place.   Thanx in advance.   Gary
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2012 at 8:47pm
You can if it's a single speed 540 shaft.It's probably easier to remove the three 3/8s bolts in the triangular piece and then pry out the seal and replace it.The bolts hold the shield and the triangular piece onto the tractor.There is an O-ring that should be replaced if that's the way you do it.On a 540 & 1000 RPM system,you have to remove the lift arm housing to change the seals.
