185 Lift arm cylinder
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Topic: 185 Lift arm cylinder
    Posted: 14 Jul 2022 at 1:41pm
I have one leaking. ReedE at the Farm-Store got me fixed up with the new seal and wiper. Can't get the front pin out! Did a search on here, MACK had advice to use a hammer and chisel to getting it moving, I had that thought in my head before hand and gave it a try. No avail. My next move is bigger hammer and chisel. If that doesn't work I may heat it with the rosebud. Is there any reason I shouldn't? I power washed the whole tractor with special attention of this area and will have an extinguisher handy, don't want a fire.
I would really like to get this job knocked out Saturday, tractor pull Sunday at Colfax and the combine needs to get out soon for it's fall prep. Also would like to use the 185 to do a little spraying yet this year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2022 at 3:06pm
When I cannot easily get out the pin, I do it right on the tractor. Pull the upper pin and physically lift the hitch clear up to get some room to work.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2022 at 7:12pm
Drive chisel against inside end of pin AFTER releasing tension/pressure on ram by disconnecting hitch. work pin back and forth till you can grip it with vice grips and twist till it comes out
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 9:12am
Thanks for the ideas guys! I'll report back how it goes.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2022 at 8:29pm
Take a torch and cut the head of the 12 point bolt off behind the pin so you can unbolt the cylinder mount from the tractor, then put it in a press to push out the pin, the cutoff bolt can then be removed with a visegrip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2022 at 6:42am
I have the pin 'moving' now. It's not out but at least it moves. Just needed a bigger hammer.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2022 at 6:53pm
Dumb question but, you do have the hair pin removed from lower pin??
 I went to help cut out a pin with my sawzall, the hair pin was still in it, a little penetrant a little heat and we had both pins out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2022 at 8:00am
Yes, the hair-pin is out. It wasn't that bad to remove. I'll get this in time, just keep it working back and forth. It's moving easier but can't twist it with pliers yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 2:46pm
Persistence pays off! Got that stupid pin out this morning. I just kept working it back and fourth and spraying it with JB80. Finally got to where I could turn it with pliers, downhill after that. Cleaned up the cylinder and took it apart. Reed had me up to speed on how to disassemble, would have been lost without that! Changing the seal and wiper was pretty easy. Got it back on the machine then went to change the 'fuel' filter that got beat-up removing that pin. Well, that's where the fuel filter is on the 6080. Turns out that's the hydraulic filter on a 185. Luckily, had 2 on the shelf. So the old girl got some unexpected maintenance today. Stared up and cycled the three-point several times, no leaks detected so far.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 6:20pm
This page was generated in 0.057 seconds.
