185 hydraulics
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: 185 hydraulics
    Posted: 24 Dec 2022 at 4:03pm
Picked up a 185 last weekend, when its first started there's no power steering or power director. The remotes work. Would this most likely be a sticky priority valve? Takes 5 minutes or more before I get steering and can move. Power director slips in high also but I'm hoping that just a linkage issue. Previous owner said stepping on the brakes while in high range it would slow down and then hold. I dont see how that would be the case and it didn't work for me, it still slipped. Its something I'll look into when its warmer and I have more time to mess with it.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2022 at 4:33am
Slipping in hi pd more than likely broken plates?
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2022 at 7:35pm
Two problems at least. If it takes 5 minutes to get steering, the pump isn't pulling oil up and out of the sump. Could be a bad pump shaft seal (pulling air) or the internal seals of the pump need to be freshened up. 3-point hitch working, means lifting a LOAD, not just going up. Power director issue may be a stuck pressure regulator spool in the power director valve. Linkage not generally an issue, unless the lever detent isn't allowing full lever stroke then lock. High side only problem may be the stuck pressure regulator or broken discs in the clutch. Verify pressures at the manifold where the brake latch is mounted.
This page was generated in 0.402 seconds.
