180 fuel gauge |
SteveMaskey(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wellsville, MO Points: 610 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Aug 2019 at 8:39pm |
Fuel gauge quit working on my 180. How do you tell if is the gauge or the sending unit?
Pete from IL ![]() Silver Level ![]() Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
Take the wire off at the sending unit and with the key on touch the wire to anywhere on the tractor (ground the wire). If the gauge is working it will show all the way full or all the way empty(I can't remember which). If the gauge does not move when doing this then check if the gauge has power going to it,(test light). If it has power going to it and it will not move by grounding the sending unit wire then the gauge is bad.
