180 floods when tank is full
chuck linn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck linn Quote  Post ReplyReply Direct Link To This Post Topic: 180 floods when tank is full
    Posted: 02 Jul 2015 at 6:59pm
180 gas will flood when tank is full or near full as tank gets closer to empty runs and starts normal is the needle sticking or something else wrong thanks for looking
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 8:30pm
Needle and seat may need replaced.  What is the condition of the float?
8050/8030/185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8050/8030/185 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 9:09pm
Definitely a needle and seat  and float problem. Pull the carb and give it an overhaul. Make sure you have a brass float. Depending on what the needle is made out of Gasohol will affect the operation too.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 10:03pm
Make sure the new needle has a rubber tip.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2015 at 11:10pm
Before you go into the Carburetor check the vent in the gas cap. Just run it slightly loose. Just might be an easy fix.
This page was generated in 0.077 seconds.
