175
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Topic: 175
    Posted: 02 Aug 2017 at 7:59am
Auction half mile down the road has a 175 on it. In the event it goes cheap what is it?   Retinned D17? Can the PTO be engaged and disengaged from the ground?   Trucking shouldn't break me.   Lol
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 8:57am
Tractor data says it's live PTO but if it's like the one-seventy you will have to depress the foot clutch to stop the transmission before engaging the PTO or else gears be a grind'n.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 5:31pm
Early 170s were basically aD17 in new medal. The 175s had a few differences, front end and hyd pump drive, I am sure there are more but don't know them all. Still has same pto system as D17 and such, live with power director but must depress clutch to engage.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 8:47pm
Much better power steering and most had 18.4's-- big plus to me!
jbirnsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 8:50pm
Make sure it doesn't jump out of 3rd gear. PTO needs clutch to engage but power director for live power.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 9:02pm
PTO is much the same as D17.  Another difference is the Perkins diesel engine - very reliable and efficient.  Power steering is fully hydraulic, not power assisted mechanical like the D17.
It will probably go cheap because it is not highly collectable like a comparable D17 Series IV.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2017 at 11:07pm
Early 175's had the same side hydraulic pump as the 170's....late 170's had the front hydraulic pump like the late 175's. I think the ones with the side hyd pumps were less trouble and the front end is heavier because the casting is not hollowed out. My 175D with side pump is my main tractor, no $800 front shaft and coupler to wear out.
ALLIS EXPRESS!
This year:
