175 D fuel injection pump
Longmeadow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Longmeadow Farm Quote  Post ReplyReply Direct Link To This Post Topic: 175 D fuel injection pump
    Posted: 22 Apr 2022 at 8:54am
My 175D CAV(DPA/Lucas) type 3248850 mechanical advance injector pump is leaking fuel from around the throttle shaft. How hard is to remove the top cover of the pump as I want to replace the seals on the throttle shaft. Actually I found a kit with a new throttle shaft included. Are there any precautions I need to take? I noticed that a metering screw passes through the top cover...??? I've consulted an IPB drawing and it kinda looks straight forward with just one stud holding the throttle and shut off shaft(s) cover. Should I be concerned about 'wear' where the throttle shaft goes through the cover? Other than the fuel leak, the pump seems to be working fine.
Thanks for the assist
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2022 at 1:06am
Carefully remove the cover and take note of where all the linkages go...install new o-rings, reassemble and bleed the system. Gasket should be reusable, make sure you get it centered right. I have done a couple without problems. I went to a diesel shop and the guy new exactly what o-rings I needed, gave me some for free.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Longmeadow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2022 at 8:41am
Thanks for the assist Eldon
This page was generated in 0.123 seconds.
