175 Allis Injection Pump
AllyCat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllyCat Quote  Post ReplyReply Direct Link To This Post Topic: 175 Allis Injection Pump
    Posted: 10 Sep 2012 at 6:03pm
The "End Plate" gasket/seal on the pump is leaking. Tightened 4 screws, but no change. I guess I will send to pump shop for repair. To remove pump I believe there are some bolts/nuts under the engine timing cover that must be removed. Do I have to remove radiator to get to these? Also, will removing bolts/nuts allow anything to fall down into engine? Thanks for any advice.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:21pm
Just drain the coolant and remove the hose to get the cover off. There are bolts in there that have to come out in order for the pump to come off. Nothing will fall out of place....
ALLIS EXPRESS!
This year:
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 9:22pm
It is uncommon to see a CAV DPA pump leak there. Usually it's the throttle & Shut-off shafts. Very simple pump to pull and re-install. No internal timing marks to line up, just the dowel on drive gear, and chisel mark on mounting flange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllyCat Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 9:54pm
Thanks guys, you provided the guidance and confirmation I was looking for.
