170 loader capacity
Channel_Seedsman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Channel_Seedsman Quote  Post ReplyReply Direct Link To This Post Topic: 170 loader capacity
    Posted: 17 Sep 2012 at 6:33pm
How much can a 170 with a loader lift? I would need to lift about 3000 pounds off a semi trailer. With full rear weights and loaded tires would it be heavy enough? thanks guys
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2012 at 7:54pm
Sounds hard on your front end to me.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2012 at 9:05pm
You are asking for trouble if you want it to pick up 3000 lbs.  You could probably handle it if you had 2 tractors lifting at the same time.
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2012 at 1:06pm
To lift 3000 lbs on pallet forks you would need a forklift or a +100 hp tractor. You would have to have a loader with 3.5"-4" cylinders to raise that much weight.
CT
2014 LS P7010C, 1962 Farmall 504 Diesel (1st tractor) w/ 2008 Koyker 220 FEL, 1968 Allis Chalmers 180 Diesel, Komatsu PC38UU-2 Excavator, Various attachments for all!
