160
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Topic: 160
    Posted: 22 Mar 2015 at 7:13pm
I went to look at a 160 today that someone had started to rebuild and then decided he needed a tractor right now and bought another one. Had not even been into engine yet, just the front end off. Has anyone overhauled a 160? He said it had been smoking and started putting oil out the exhaust pipe. I know some parts are getting hard to get as I have a 160 already. Just wondering thoughts from someone that worked on them. Tires and sheet metal all good. Thanks
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2015 at 8:25pm
Shouldn't be a problem getting parts for the Perkins 3.152 as there are millions out there.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2015 at 5:30am
Same engine as the MF 135, industrial 20's
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2015 at 5:42am
I think you will find parts for the Perkins engines significantly less costly than for most AC tractors and like they said above, readily available.
Edited by WF owner - 23 Mar 2015 at 5:42am
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2015 at 6:17am
I had the same engine in a Massey 235, very good motor and fuel efficent. As comon as they are you could also buy a factory reman I'm thinking, will cost more than if you do it yourself but prolly comes with a waranty.
H Clark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H Clark Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2015 at 8:27am
I rebuilt mine a couple of years ago. Got All of the parts thru a massey dealer.
1960 D-12,1948 WC, 1973 160, 1977 175, 1984 6060
