160 puking oil out around shift lever |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2880 |
Topic: 160 puking oil out around shift leverPosted: 24 Sep 2016 at 8:40pm |
I have noticed oil on top of the tranny of my 160. Today while going down the road I looked down and seen oil coming up around the shift lever. Seems to only do this at higher rpms. Bad shift boot or worse?
plummerscarin
Posted: 25 Sep 2016 at 12:09pm |
Uncle's 185 does the same thing. Says there is a seal on back of trans case that separates it from the next one and that is a split job to replace seal.
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 25 Sep 2016 at 12:24pm |
How does oil get to the lift cylinder on the 160? On the d serries there is a hydraulic line that goes to the lift cylinder and if that line brakes it will do what you discribed when you try to use the lift. I am betting your hydraulic oil is low.
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 25 Sep 2016 at 2:42pm |
If both compartments use the same oil you can do the poor mans fix and connect both together with a hose/fittings so that the level will stay the same in both.
1957 WD45 dad's first AC
Leon n/c AR.
Joined: 19 Mar 2013 Location: Heber Springs A Points: 176 |
Posted: 25 Sep 2016 at 3:39pm |
There should be a vent for the trans and hydraulic reservoir, if plugged it will force oil out. Leon
