100/200 Series Tilt Wheel ? |
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Oct 2021 at 8:30pm |
How many of you guys utilize this feature on the old gals ?
Was this available on any smaller model than the 190 ? Thanks
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8721 |
I use it on my one ninety/one ninety XT.
On my XT however, it needs to be snugged up a bit, as the steering wheel keeps settling to the down position Darrel |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
I use mine when I stand up and drive.
Don't think it was on lower models. The 190 was very progressive!
Charlie
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5238 |
I set mine to the position I liked and haven’t moved it since. Neat feature for a tractor back in the 60’s to have. Can’t think of any tractor before that having it. I know AC pushed that feature in their literature and dealer movies. Not sure how much of a selling point it was but it was all about the console control and large floor area designed for comfort. And it is a comfortable tractor to operate so they got it right in my opinion.
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 965 |
I'm not sure if was available on smaller AC 100 series. I've only owned 5 180/185 none of them had it. The tilt and extend is nice in 200's, changing position on long days helps.
LMAO !! I put the seat up into the "2,nd" position without hoisting the entire seat assembly through the "notches" of the incline ![]() ![]() ![]() ![]() Yes , ALLIS was WAY ahead of the competition back "then" far most of their products, the PTO ( non -live) should have been addressed in the "early" '60's IMO
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
I have that on my 200. With the factory cab, I can't stand up and drive. It works but I've never moved it after I set it several years ago.
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1031 |
My 200 has tilt and telescoping steering wheel. Were both features included in same option or was it available with tilt only? I use the telescoping feature quite often but rarely change the tilt.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21998 |
I remember the telescope feature as an option and maybe not on the first 200's, but later on.
Now my curiosity is building; have to see if my newly aquired 200 has telescoping steering wheel.
I know that it has tilt Darrel |
After looking in parts book on my 200 it appears the telescoping feature started with Ser.#4001
That's the same time the 200 changed to the "Gated" PD control. These are the 200's some people refer to as "price cutter" models even though they had upgraded PD control and valve and offered telescoping steering wheel.
The 200's replacement, the 7000, had the telescope steering wheel as an OPTION.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5134 |
![]() [/QUOTE] Oliver had a tilt/telescopic steering wheel starting in 1960, AC didn't have it until 4 years later. AC was a bit lagging behind on this feature, as well as the mentioned TRUE IPTO.
I finally remembered to look at my 200 to see if it has telescoping steering wheel; it does, and it works ‼️😃
Darrel |
