190xt PTO Lever Question
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt PTO Lever Question
    Posted: 10 Jun 2026 at 5:54am
My new to me 190XT has two  PTO levers.  One is installed in the floor and the other is installed in side console which is supposed to be a hydraulic version, I believe.   The side console lever doesn't move at all.  The floor lever is what engages the PTO now.
Did this tractor have Hydro PTO at one time and someone replaced it with the floor lever?  I haven't taken the console shield off to investigate.  I don't think it would come with two levers from factory?  I read operators manual but not a lot about the hydro version.
It isn't giving me any problems but am curious why two levers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2026 at 6:25am
The PTO valve is located under the platform directly down from the lever......if it is there.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2026 at 7:59am
I looked through my pictures to see if I could get a picture of the valve. I found one. It isn't clear, but it does show valve location.
If it has the hydraulic valve try spraying WD40 or similar into the console and waiting a day to see if the detent loosens up. I usually just fog some in around the remote levers. I learned recently(from this forum) that all 190XTs with a PTO have the disconnect lever on the left side, but on hydraulic control models nothing was hooked to it. It sounds like yours may have been modified since it left the factory.
Ted
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2026 at 8:18am
That blue circle is the Power Director valve. The hydraulic PTO clutch valve (an option) is 16 inches to the rear of that blue circle, if it has one.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2026 at 8:32am
The hydraulic PTO lever can seize up. I think it's just the detents. I have not had to deal with it personally. But have seen handles welded and bent from people pulling on them. Need to spray with something better then WD40
Edited by DanWi - 10 Jun 2026 at 8:34am
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2026 at 1:59pm
Remove the linkage from the valve  - see if the lever moves.  See which is froze. The PTO valve is almost identical to the PD except with no relief system.
AMDG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMDG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2026 at 8:43pm
This thread is very timely. I have a 190. I Hadn't used the PTO in a while. Just a few days ago I tried it and was very stiff to move, almost locked up. I used a good penetrating oil and sprayed "Free All" using the straw into the cracks around the pto lever and into the openings around the hydraulic levers on top and works smoothly again. So guessing your right about lubricating the detents
Ad Majorem Dei Gloriam
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2026 at 8:47pm
This is a new one to me. I have never seen a XT with both levers, one or the other. Mine is hydraulic, lever on the console. A friend of mine early 190 is on the floor left of the seat. Sounds like the console may have been upgraded since you say it is presently engaged by the lever on the left coming up through the floor?
Edited by AC720Man - 10 Jun 2026 at 8:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2026 at 8:58pm
If you look behind the battery box, I'd bet your mighty 190/190XT has the short manual lever already protruding from the torque housing. It has the hydraulic PTO clutch, so the left hand platform lever was never installed at the factory. Why the original posters tractor has two levers, I have no idea. I doubt that it left Milwaukee like that.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2026 at 5:44am
Going from the hydraulic PTO engagement which is on the side of the console, to the lever coming out of the floor which is a manual connect/disconnect is going backwards. My guess would be that the tractor came from the factory with the hydraulic PTO option, and at one point in its life, the rear end got swapped out, and the doner rear end didn't have the hydraulic option. If you find evidence that the hydraulic PTO is still in there, but the lever is just seized up, by all means, free it up and use it.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2026 at 7:18am
Couldn’t you just look at the pto drop box to see if there’s hydraulic lines going into it or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2026 at 9:03am
I took pictures of it and compared to AGCO Parts diagram.  I believe it is still there and lines going to it but not totally sure what I am looking at just yet.  I need to remove the cover.
Picture showing both levers.
I believe this is the valve showing linkage and lines connected.
Here is the parts diagram for the PTO Valve.  I see 3 lines connected as in the diagram.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2026 at 9:30am
It appears the PTO hyd valve was added on after the tractor was built. There's no paint on it or the lines going to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2026 at 9:54am
That makes more sense than adding a manual lever later.  I wonder if they tried to add it and gave up?
In order to use a hydraulic version, you would surely have to de-install the manual lever, or could both work?
I will take that cover off and see what I find as to why the lever is locked up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2026 at 10:23am
The hand lever to the left of the seat was normally left off when factory equipped with the hydraulic PTO OPTION.  BUT, if you look behind the battery box and follow the link rod from the hand lever down to the torque housing, you will see a short lever that came on EVERY tractor at that time. So, BOTH types were on every tractor that had a hyd PTO clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2026 at 3:30pm
That's interesting.  I suppose they could have put the hydraulic version on and then it broke so they put the long lever back on.  In order to use the hydraulic version, do you have to push the clutch in like the manual one?  Trying to figure out the advantage of the hydraulic PTO engagement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2026 at 8:55pm
The hydraulic could be engaged on the go. No foot clutching.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2026 at 8:59pm
You don't have to use the clutch to engage the hydraulic clutch. I do use the foot clutch if it is a heavy load, if for instance you don't let your baler clean out at the end of the row, or when you first start it for the day. I think it is more likely that someone added the lever to the mechanical (left) side when they had problems with the linkage on the hydraulic. It has been a lot of years since it left the factory, hard to know. I have a 190XT that has a 200 serial number, so I know at least the torque tube has been changed.
Ted
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2026 at 10:21pm
The hydraulic also had a braking function didn't it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2026 at 3:48pm
Yes, two pistons on each side of the hydraulic feed line.  The pistons are hydraulically tied together and push on the front of the PTO clutch housing.
Edited by tbran - 12 Jun 2026 at 3:51pm
