WTB Powershift filter part
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: WTB Powershift filter part
    Posted: 22 Aug 2026 at 2:53am
While changing oil on my new to me 7060 I discovered the plastic part that you snap onto the filter has a piece broken from around the bolt hole, not a very big piece missing but still broken. Not sure I need to get another but I thought I would ask if anybody has one of these in good shape they would part with?
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 6:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 6:52am
The more I look at it it looks like to me the only purpose for the piece is to guide the bolt, why not go ahead and remove the rest of the broken piece so it doesn't break off more and take my time when installing the canister?
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 7:39am
Might of found one.
I have this tractor apart draining all the oil and filters and screen out. Had to order one more of those thick rubber seals for the large tubes going toward the belly filters since oil out and they are weeping. Just want to put it together correctly and be done.
Edited by whatscooking - 22 Aug 2026 at 8:09am
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 8:16am
Check out the online AGCO parts catalog or get ahold of your dealer - you can still get a new one if you want.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 8:54am
AGCO Part # Is 70269961 you must use for the light to work on the dash
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 9:06am
I called my dealer last night and a different person that I normally talk to said not advable. Just now called and was told can order $140.00.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 10:19am
Found anew one
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 2:31pm
Sounds about right, ha! I am lucky that I can look up the part I need 99.9% of the time, and the other .1% of the time, I ask my dealer and the owner just knows off the top of his head that "oh yeah it subbed to this part number back in the 1980 but that didn't get into the online catalog" or something similar. I'm glad you were able to get fixed up one way or another.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 5:18pm
I was afraid used was all i had left. I have found some honey holes along the way. I even found a place that has several salvage ALLIS-CHALMERS tractors under roof.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 5:25pm
All the broken piece does is guide the long draw bolt to the threaded hole in the base. However, anything that breaks off in that area, winds up going into the PST valve unfiltered. So, break it off clean or get a new one. I thought AGCO didn't have them anymore ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2026 at 5:49pm
When I saw the damage I suspect someone dropped the filter into the canister and chucked that piece off, I hope they caught it, I cant see or feel anything. I was ready to dremmel it out and thought it centered the top or muck up the sensor so like I say cry once.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 6:02am
My dealer is fantastic, had all filters and seals and gasket in stock and gives 10% for not using visa. I found this part # and called Mark again and got another person,I asked 3 times and got nope. I only talk to Mark from now on.
Who is your dealer?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2026 at 10:32am
Who is your dealer?
Try calling Dittamore Implement (217) 500-3194 in Teutopolis, IL and ask for Chris in parts.
