What kind of oil to use
oemj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oemj Quote  Post ReplyReply Direct Link To This Post Topic: What kind of oil to use
    Posted: 20 May 2017 at 3:34pm
I just purchased an Allis Chalmers WD 45 tractor. I want to know what kind and weight oil to put in the rear end, and where the wet clutch is. Can I use synthetics where the wet clutch is? What weight should I use in the rear end? What weight for the wet clutch? Can I use any hydraulic oil for the hydraulics?
I've never had any piece of equipment with a wet clutch, so I don't want to ruin it.
Thanks, I have a manual coming, but don't have it yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 5:52pm
You can use any Universal hydraulic/transmission fluid in EVERY compartment on the tractor except the engine. Synthetic??? why so expensive of an oil when plain old Hy-Tran will work......
oemj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oemj Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 7:52pm
Thanks, but I should get different weights right? Like 85-90 for rear end, 20 weight for hydraulics, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 7:58pm
NO !!! !    one oil in EVERY compartment as long as it's a Hy-Tran type fluid. You'll need 5 1/2 gallons to refill everything except the final drive pans which take about 1 1/2 quarts each. You could use 80-90 wt in them if you like or Hy-Tran.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 8:03pm
Some use the 85-90 weight oil in the final drives as those pans tend to leak anyway, and the Hy-tran is lighter than the 85-90.
WC, CA, D14, WD45
oemj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oemj Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 5:39pm
Would I use a 85-90 weight wet clutch?
What weight should I use on my hydraulics?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 7:04pm
As Dr Allis said......you can use Hy-Tran everywhere except in the engine. Hy-Tran is a combination oil that was developed well after your WD45 was built....it works for both hydraulics and in the tranny, differential, etc. I used 85-90 gear oil in the finals only because they are leaky and it's heavier than Hy-Tran.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 7:37pm
Would I use a 85-90 weight wet clutch? NO
What weight should I use on my hydraulics? Like everybody said, Universal Transdraulic Fluid.
https://d2ul0w83gls0j4.cloudfront.net/products/48/1200/481440.jpg
https://d2ul0w83gls0j4.cloudfront.net/products/48/1200/481440.jpgWalmart has the same thing in "Super Tech" so called heavy duty transmission and hydraulic oil.
Edited by CTuckerNWIL - 21 May 2017 at 7:54pm
