What did you do with your Allis Today?
 Post Reply Post Reply Page  <1 22232425>
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 11:00am
This is what I did with my Allis today! Big smile
(She drove for the first time in at least 40 years I'd say, off the trailer onto the driveway at last)
Edited by ekjdm14 - 28 Jan 2025 at 11:03am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2025 at 11:55am
Good to see it moving under its own power!
Mike, I just might take you up on that. I’ll keep that in mind as we get in to warm weather
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2025 at 7:27pm
Ran the spring tooth harrow with the wd 45 many many times over the field trying to level up from a rough plowing job
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 5:59am
I was just thinking of you yesterday. Needed a weight and spotted my small anvil on the bench. That reminded me of your plowing exploits.
Serviced the air cleaners on both 45's yesterday. Put the carryall on the wide front for a tractor ride Saturday. Got the 185 and planter out and did a test pass, all systems go just need dry conditions.... Got the 6080 out to remove the loader on D-17-1. Got that done without killing myself. Left the mount brackets on for now.
That tractor will be sold at some point in the future, not sure weather to sell with the loader on or separate them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2025 at 8:35pm
On the 170, replaced the cross over shaft assembly for the traction boost control. The original was siezed and broke the shaft end off where it connects to the 3pt. Got it from L&L
The 7040 got a pair of LEDs to replace the orhi/lo beams. Looking forward to see how they work in the dark
Got the 190XT running again after a tip from a forum member. Can go in to more detail on my other thread
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2025 at 6:16pm
Planted 13 acres of oats. Actually 12.67 acres. Ran one bag short. First time using the mounted all crop grain drill. Learned a bunch. Thought i had it ready to go. I was wrong. Hooked up the support chains. It never occurred to be that the previous owner maybe had smaller rear tires. I hooked up the chains, lowered the drill and was a couple inches short of the ground. Fertilizer rate is more of a very broad range. New winter project part two
55allis View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2025 at 7:13pm
I went and harvested (not really) with the ol 410.
Think I have an overkill of a tractor? Needed my duels on for the picture!!
Really was just was moving the harvester.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 7:20am
Planted corn like it was 1985!
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2025 at 6:14pm
Moved a few things around with that 190XT
Might be able to use it tomorrow to work over the sweet corn patch
1950AllisWD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1950AllisWD Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2025 at 10:31pm
Did a little work on a new to me snap coupler blade. Got it mounted on the 15 and put it to work.
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2025 at 12:02am
Nice pictures guys. I used the 9735 agco-allis and 8702 white planter to put in the corn plots. 25 different varieties each plot about 2200 by 30 feet. had my daughter and wife helping, started about 1 and just got done about an hour ago. Now just planting out the leftover mixed seed. If I don't run out of steam I should get this field in by 2. Supposed to start raining at 8 so I want it done.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2025 at 5:45am
I agree. Good pics
Thanks for sharing
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2025 at 11:38pm
Today I hooked the offset to the 7000, and my brother started disking some small patches that are going to be planted to teff. I started pulling the water pump off the recently purchased 190XT series one. Not today but sometime this week the mower was put on the 190XT series three.
Ted
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 6:45am
Yesterday planted one neighbors sweet corn with the ca and 2 row planter. Today will do 2 more neighbors sweet corn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 4:29pm
7045 and DA385 got the beans in
190XT and 3pt spring tooth harrow worked the sweet corn patch. 170 and green 4 row planter got the first batch of sweet corn planted
Funny thing about that open station 190XT, it feels really high off the ground compared to the cab tractors
Edited by plummerscarin - 11 May 2025 at 4:31pm
Jgranat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgranat Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2025 at 7:44pm
I removed the PTO stub shaft seal retainer, stub shaft and bearings today to fix a leak on my WD45. It may require a sleeve to fix it proper, shaft is pretty rusty. 2 new seals coming to my mailbix, hope to have this fixed and the 4 basket tedder pinned to it by Friday to test the hydraulics and see if she will fold and unfold it for me. I had a good Mother's Day for a Father....
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 7:34am
Neighbor gave me a Massey Ferguson dirt scoop. Fitted it to the 175 and played with it improving the lane. Ended my quest for a D series when I found a '57 Series 1 D17 last week. It's in pretty nice shape, good oil pressure, power steering, front end good, tin is good, has not had a loader on it, runs like a top. First tractor I've had that has snap couple and working traction booster with gauge. That "500 lb" snap coupler to 3 point adapter came with it. Needs tires and wheel but have that covered. I'm now the third owner; Story is the first guy bought it new, used it for a small farm, he died, the son sold it to the second guy.
He bought it to plow driveway, got it home and found he had more tractor than distance. He put new plugs, manifold gaskets, fan belt in it. I'm going to hook it to a couple windfall aspen this morning and see how it behaves under a little load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 7:37am
TedN what do you do with your teff you planted
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 9:03am
The teff is a new thing for us, the plan is to make hay with it. My brother runs the farm, I help when I can. We produce small bale(16x18) grass hay and alfalfa, he has a yard he rents on the other side of the state where he does direct sales every Saturday. Right now teff seems to have a lot more demand than supply, so we picked up some small fields that weren't being farmed and we are going to try something new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 9:22am
Yesterday we used the FR30 to clean up the grain bag that split open. Scooped up about 12000 bushels of spilled corn. Majority was dumped directly into the super-b trailers using the loader. The first stuff went fast only taking about 15 minutes to load 45 metric tonnes but the cleanup took a lot longer. We first used the old skidsteer to dump into the loader bucket and then dumped that into the trailer. Cleaned the last bit up using the grain vac. First (and last) time using grain bags.
AC5030Mark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC5030Mark Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 9:30am
Got my new to me 1981 AC 5030 running after many many years of sitting in my neighbors field. He finally sold it to me.
JSHIVERS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JSHIVERS Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 6:19pm
Took the 1940 B to our nearby antique machinery club show this past weekend.  I power washed it and had it all spiffed up.  Best part was I was able to drive two of my grand daughters around the grounds.  Big smiles all around!
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 6:17pm
Put the box blade on the 170 to work over the driveway.
Then....
Grabbed the Woods to try getting a handle on this thistle patch. Hopefully I got to it before the seed pod developed
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2025 at 7:06pm
the only answer to those thistles is a weekly dose of 2,4d
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2025 at 10:11pm
Taught Mollie a bad habit
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC5030Mark Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2025 at 10:22pm
Lontrel. 1 spray. Only thing I have found to work that well.
Dawson Winthrope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dawson Winthrope Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 1:34pm
Nice work getting out there between the rain! Mowing the trail sounds like a great way to make use of the Allis and give the grandkids some room to roam. That carryall setup with the box on a pallet is a smart idea versatile and practical for all kinds of jobs around the property. Thanks for sharing the video too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2025 at 7:00pm
Put the last batch of sweet corn with the 170. Then pulled some scrubby trees out from the base of the windmill with the 190XT.
ibleedorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ibleedorange Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2025 at 12:02pm
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2025 at 5:12pm
Got mower, rake and rotobaler greased and ready to go. Maybe we get a window this week. I guess 30% of the ground around herr hasn't even had primary tillage yet. Rain is crazy this year. Almost no corn has been planted and the corn that has is yellow with crap stands
This page was generated in 0.085 seconds.
