WD45 Diesel Gearing? |
GlenB(IA) ![]() Bronze Level ![]() Joined: 11 Sep 2009 Location: Iowa Points: 127 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Dec 2011 at 12:32pm |
I am rebuilding by grandfather's WD45 diesel. The previous owner ran the transmission and rearend dry. He wore out the differential ring gear and pinion shaft bearings. The bearing spun and ruined the housing (cracked). If I bolted up a rearend from a WD45 gas, would the gearing be a whole lot faster, or slower? Would I really know the difference? I realize that the serial number would be lost. Thanks!
dustinmo ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Auxvasse, MO Points: 2187 |
the gearing would be higher on the gas rear meaning you would go faster in each gear if you put the gas rear in the diesel, the d230 turned more rpms than the gas to get the same hp,
Thank you, Dustin. Has anyone done this? Would it be too fast?
Bill Deppe/AC Salvag ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 974 |
Believe I could have a complete 45D transmission and housing assy 563 652-2949 Ia
won't be much faster. MACK
Chris/CT ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
I also have a bare housing and ring gear assy's if you decide to put back original. Serial no on housing has a 45D serial no.
Larry(OH) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Hey Mack, how much difference is there. I hear around here from all the WD pullers that they are looking for a diesel rear end because its slower/lower. I always wondered how much slower
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
The WD-45 gas ran 1400 rpm and the diesel ran 1625 rpm so the gearing makes up the differance to get the speeds the same. The crown and pinion in D-17's are the same as the WD-45 diesels so should be easy to find.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21865 |
Approximately 15 % difference....1400 rpm x 100% divided by 1650 rpm = 84.8 %
TexasAllis ![]() Silver Level ![]() ![]() Joined: 14 Sep 2009 Location: Texas Points: 396 |
I can't imagine for everyday use you would ever be able to tell the difference except maybe in first or second gear.
The pto speed may not match the grouind speed use in some cases |
