D-17 Steering & Fender Question |
Post Reply ![]() |
Author | ||
Wendell,W.N.H. ![]() Bronze Level ![]() Joined: 28 Jul 2012 Location: Langdon,N.H. Points: 28 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Jan 2015 at 5:40pm |
Just got a 67 D-17 diesel that has a steering issue. When you go to turn the wheel there is a little resistance but then the P.S. will kick in and turn the wheels ok, but after that it doesn"t seem to relax, so you need to keep steering al the time. You end up using all the road for sure, and don"t go to fast! Is this a problem with the control valve? Also does anyone know where to get some decent fenders? Thank you in advance for any help.
Sponsored Links | ||
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Steering valve needs new orings and readjusted. MACK
Pete from IL ![]() Silver Level ![]() Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
Mine did the exact same thing. The nut had come loose that that holds the shaft that goes through the steering valve.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5022 |
A good friend of mine would ask if it could be the nut behind the steering wheel...
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7505 |
The steering shaft is splined and so is the steering wheel that goes on it. I've never seen any of those nuts work loose - they all rust in place! |
Read my post again. I think you will agree that "the nut behind the steering wheel" is responsible for most of the tractors problems! |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5899 |
Now Myron don't embarrass us other guys from the frozen North LOL Gary |
Thank you for your help,Taking her apart now.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Ted J ![]() Orange Level ![]() ![]() Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
I was taught it was the LOOSE nut...
Post Reply ![]() |
