D14 no PTO power
barnabas_12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnabas_12 Quote  Post ReplyReply Direct Link To This Post Topic: D14 no PTO power
    Posted: 18 Aug 2012 at 10:07pm
My D14 is somehow not getting full power to the PTO.  Running my haybine, the PTO slow to a crawl in thick stuff.  My forward speed is not changed, just PTO power.  I'm not sure how this can even happen.  Any ideas would be appreciated.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 10:31pm
I don't know much about those new tractors but there must be a clutch somewhere that is slipping? Does it have something to control the pto seperate from the ground speed, like a hand clutch on the CA's and WD's?
Edited by MNLonnie - 18 Aug 2012 at 10:31pm
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 10:42pm
I don't think there is a clutch for the PTO on the D14. It uses the main clutch on the engine flywheel. If its slipping, your forward speed would also slow. Does your haybine have a slip clutch somewhere?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2012 at 6:53am
If the PTO really is slowing down, it has to be the foot clutch slipping (which would also slow down your ground speed) so the next time it does this "slipping", stand on the brakes really hard and try to kill the engine. If the tractor stops moving, the foot clutch is slipping. If it kills the engine, you have a belt on the haybine slipping that drives the machines sickle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote barnabas_12 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2012 at 9:58pm
Thanks for the advice.  I was able to brake without kiilling it.  Looks like I'm doing a clutch job.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2012 at 12:09am
And the PTO quit turning too when you did this?
This page was generated in 0.050 seconds.
