d19 charging system
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Topic: d19 charging system
    Posted: 04 Jun 2012 at 9:22am
had generator rebuilt this spring due to low output and bearing failure. rebuilt unit put out a very accomidating 20 amps plus. finished field work. miminal amp output. measure voltage @ run from battery @ 10.8 to 11.1 volts.  at generator, same. lights on, same. suspect faulty rebuild. would like directions on test measuring voltage regulator for performance. 3 wire assy. thankyou in advance.....bolivar boy.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 9:51am
You should have BAT volatge at the BAT terminal on the VR. If so the next thing to do is jump the F terminal on the gen to ground. This should make the GEN go to full field and charge 100%. If it does you have a VR/wiring problem. If it doesnt then you have a gen problem
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 12:35pm
After you short the F to ground and if it still doesn't work, pull the belt off, disconnect the F wire from the gen, and apply battery voltage to the A terminal. The gen should spin fast like a motor. While motoring, ground the F terminal. It should slow down but continue to motor. If it passes these tests, load test your wires. If they all pass, your regulator is faulty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 2:12pm
thankyou fellows. just what i was looking for........best regards. tp studer.
