D-14 clutch
mherndon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mherndon Quote  Post ReplyReply Direct Link To This Post Topic: D-14 clutch
    Posted: 27 May 2012 at 11:46am
Do you need to add shims behind the flywheel if you have it faced? My clutch pedal does not set up very much.
Mark
D-15, Old dealer in Smithville, TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 12:06pm
No. Any time a flywheel is faced, it should have the step faced too to keep dimensions the same. There have been posts on here about replacement clutches being thicker than originals causing problems.
BIG MIKE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BIG MIKE Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 12:08pm
Should be able to take clutch rod out of pedal and it will thread outward to raise pedal.Thats my thought never heard of shims being added.Also can check fingers on pressure plate.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 12:11pm
A D14 doesn't have a step flywheel. It sits down inside the ring gear,flat on the flywheel. I'd say your clutch disc is too thick,causing the fingers to dip down towards the flywheel. Check with Tracy Martin...he can fill you in on this.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 12:46pm
Just adjust the finger height.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 12:57pm
I guess a guy has to learn something every day.Smile
dscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dscott Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 3:00pm
    I' m thinking above is all sound advice. Because shimming the flywheel is only needed on a hydraulic slave cylinder setup to the best of my knowledge.
