D17D Shift Rod Detent
tcarollo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tcarollo Quote  Post ReplyReply Direct Link To This Post Topic: D17D Shift Rod Detent
    Posted: 22 May 2012 at 10:32pm
I was fooling around with my transmission control cover the other night, dislodged a shift rod and sent, what I beleive was a rod detent, off into the woods. Can I pick up a replacement detent and spring at any tractor parts place or is this a special order from somewhere?
Thanks,
TC
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 11:15pm
Unfortunately it needs to be the correct one, so you will need to find a donor tractor, or call AGCO.  Fairly often a cover will come up on ebay.  You will probably be missing a spring and a ball.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 5:34am
The detent is a 3/8" steel ball. If you remove your dipstick to the left side of the dashboard ahead of the gearshift (when sitting in the seat) notice there just might be a small cotter pin located about midway on it. If so, remove the cotter pin and throw it away.....there should be a ball up inside the tube which is the correct size. You'll have to bend the dipstick to the side a bit to remove the ball out of the tube. You do not need to replace the ball.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 6:23am
So Dr. Allis, where do they hide the extra third gear?   :-)
Still in use:
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 6:32am
Interesting -- always learning new stuff -- love this site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tcarollo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 9:57pm
Spring and ball on order. Thanks!
